Activity › Forums › Blackmagic Design › Decklink + Raid
  • Decklink + Raid
    Posted by Matt Cloak on November 2, 2012 at 10:09 pm
    Hello. I’ve got an SDI Decklink and can capture fine to my C Drive with no problems at 1920×1080 29.97fps (AVI 8-bit YUV) with 4 channels of audio. But if I capture to my Raid-0 drive, the audio has little blips in it every 10 seconds or so (the video is perfect).
    The BlackMagic Disk Speed test shows the Raid Drive is faster than my C Drive and should be able to write 1920×1080 60fps (AVI 10-bit YUV). The Raid drive is a USB 3 enclosure with two identical 2TB 7200rpm drives (running Windows 7). Is there something I can do to capture to the Raid Drive with out the audio problems? Thanks for any help with this
    Matt Cloak replied 13 years, 10 months ago 2 Members · 2 Replies
  • Alex Gerulaitis
    November 3, 2012 at 10:28 am
    Very strange. I haven’t experienced that, but it’s possibly a latency issue with USB 3.0. Does the RAID have an eSATA port as well, and can you use it instead?
    Do you capture using BMD utility (Media Express I think) or some NLE?
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Matt Cloak
    November 3, 2012 at 5:38 pm
    Thanks for your reply, Alex. I am using BlackMagic Media Express to capture. The drive enclosure does have eSata. I will try that and let you know how that goes.
