Activity Forums Blackmagic Design decklink pro very weird problem
  • decklink pro very weird problem
    Posted by Kushal Shah on October 12, 2005 at 1:37 am
    HI team
    I have run into very much weird problem so far
    Deatils of setup
    G5 Dp 2.7
    2 GB Ram
    Decklink Pro
    software versions 1 / 10.4.2. qt 7.01 fcp 5.02 bm 5,1
    software version 2 10.3.8 qt 6.5.2 fcp 4,5 bm 4,8
    i have three such systems with identical configuration
    when I try to capture from digibeta input it says no video input
    althougt when i sent colour bar from digi deck it shows up in the capture screen
    but the moment you insert the tape it says no video input
    i have tried all the possible combination of fixing the permissions and trashing kext files
    I am sure i am doing something wrong somewhere
    in all these years 20 + decklink install i have not encountered this problem
    please advise
    Margus Voll replied 20 years, 10 months ago 3 Members · 5 Replies
  • Luke Maslen
    October 12, 2005 at 1:47 am
    Hi Kushal,
    Please disconnect any cables from the DeckLink Pro. Launch either Final Cut Pro or Blackmagic Deck Control and you should see a window which says “No video input.” Now use a barrel connector to connect the “SDI to deck” or “SDI Monitor” cable to the “SDI from deck” cable. If the DeckLink card is working, the “No video input” message should disappear and just be replaced by a black display. This will prove whether the card is working correctly or not.
    Ensure the Digibeta is in “remote” mode and that the SDI in and SDI out cables are connected to the deck as well as the RS-422 cable.
    Please let us know how you go.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Kushal Shah
    October 12, 2005 at 1:57 am
    hi Luke
    just to clarify about barrel connector
    is it something like I joint or conector which has male bnc at both the ends?
    please explain also what will this check ?
    if black video comes and no input message goes then what should i do ?
    I am planning to visit client in few hours
    Kushal
  • Luke Maslen
    October 12, 2005 at 2:09 am
    Hi Kushal,
    [Kushal shah] “just to clarify about barrel connector
    is it something like I joint or conector which has male bnc at both the ends?”
    Yes, you are correct. It has a male connector at both ends. I used the term “barrel connector” as it looks like a barrel but your description is much clearer.
    [Kushal shah] “please explain also what will this check ?”
    If the “No video input” message remains when you have connected the DeckLink SDI output to the DeckLink SDI input, then the card is not working correctly and should be replaced.
    [Kushal shah] “if black video comes and no input message goes then what should i do ?”
    This would indicate that the DeckLink card is working correctly and that the problem is probably with the deck. I would suggest checking the settings on the deck, especially that it is in remote mode. Other readers of this forum might also be able to suggest other deck settings to check.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Kushal Shah
    October 12, 2005 at 2:42 am
    Dear Luke
    Thank you very much for your responce
    i would like to point certain facts here
    1 deck is in the remote mode and i can control deck from bm deck control and fcp
    2 there are three such cards in the setup and all are faceing same problem
    3 i checked sdi out from deck and its working fine
    let me know your feedback
    best regards
    Kushal
  • Margus Voll
    October 12, 2005 at 8:10 am
    Does this happen only with this tape or all other tapes also ?
    It might be possible the tape is bad – wrong format, colour, system etc?
    Margus.
