Activity › Forums › Blackmagic Design › Decklink PrePro 5.2.2 driver capture bug
  • Decklink PrePro 5.2.2 driver capture bug
    Posted by Adrian Tecson on November 22, 2005 at 8:11 am
    I just discovered a bug with the decklink 5.2.2 windows drivers. When I try to digitize either from SDI or analog component to my edit station that had the 5.2.2 drivers, the video comes in slightly shifted to the right. But when I tried to digitize it using my other station with the 5.2.1 drivers, the video comes in properly registered. My suspicions were confirmed when I rolled back the driver of the other station to 5.2.1 and everything was fine again. I was wondering if anyone ran into this probem as well?
    Here’s a link to what the video looks like;
    https://www.undergroundlogic.com/bugs/522bug_still%20frame.jpg
    My station specs are as follows;
    Motherboard: Supermicro X6DA8-G
    Processor: Dual Xeon 2.8
    Video Card: Ati radeon X300 PCI Express
    RAM: 2gigs
    Decklink Extreme PCI
    WinXP SP2
    Shane Chadder replied 20 years, 9 months ago 5 Members · 8 Replies
  • 8 Replies
  • Wolf
    November 22, 2005 at 8:24 pm
    Hi Adrian,
    i never had this problem!
    What
  • Adrian Tecson
    November 23, 2005 at 6:32 am
    I’m using PrePro for digitizing.
  • Wolf
    November 23, 2005 at 8:30 am
    strange!
    Like i said, never seen this problem.
    Perhaps it
  • Adrian Tecson
    November 23, 2005 at 6:09 pm
    Hi Claus-Peter,
    Not composite, but both component and SD-SDI. I wonder if it has something to do with my video card(ATI), although that is quite far fetched. Any other ideas?
  • Wolf
    November 23, 2005 at 9:05 pm
    i don
  • Luke Maslen
    November 24, 2005 at 5:40 am
    Hi Adrian,
    If you are using genlock, please verify that the genlock format matches the format of the video you are attempting to capture. Make sure the deck is set to use external reference (or Auto if this is not available) and that the genlock cable has also been connected to the DeckLink card.
    If you are not using genlock, then make sure the deck is set to use internal reference (or Auto if this is not available) and that genlock is not connected to the DeckLink card. Then open your DeckLink control panel and set “Black video output to deck in capture” setting to SDI or analog depending upon whether you connect to the deck via SDI or analog respectively.
    Finally, if that still does not help, try using Blackmagic Deck Control to capture video from the deck and then try outputting it back to the deck. Does that work without problems or does Blackmagic Deck Control suffer from the same problem?
    Please let me know how you go.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Helio Ricardo
    December 6, 2005 at 11:30 am
    I tried what you said, but didn
  • Shane Chadder
    December 12, 2005 at 5:48 pm
    Luke
    I’m running into this bug to. ONLY in a DV timeline capturing SDI.
