Activity Forums Blackmagic Design Decklink PCIe on PC output issues
  • Decklink PCIe on PC output issues
    Posted by Stevenghouti on October 29, 2006 at 2:51 pm
    Hi all, the happy owner of 3 Decklink SP PCI-X cards, I recently installed a Nuendo system for a client with a Decklink SP PCIe card. But what I see on the monitor is way off in terms of quality than what I’m used to with the older cards. The picture seems much more pixelated on the PCIe machine when I play a file that I have previously used on a PCI-X machine. I’m still using Photo-JPEG compression as it is the format that gave the best results on the PCI-X cards. Has the PCIe version got a different attitude towards PhotoJPEG??
    For the moment my client is very unhappy. In need of a speedy answer…
    Steven
    Steven Ghouti
    YELLOW CAB Studios
    Paris, France
    http://www.yellowcabstudios.com
    Stevenghouti replied 19 years, 10 months ago 3 Members · 5 Replies
  • Luke Maslen
    October 30, 2006 at 12:45 am
    Hi Steven,
    Are you seeing the problem on Mac or PC? PhotoJPEG is available on both platforms.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Stevenghouti
    October 30, 2006 at 8:01 pm
    Hi Luke, the problem is on a PC. It’s a ASUS P5WDG2 WS Professional mobo with a Intel Core 2 Duo E6600.
    Regards,
    Steven
    Steven Ghouti
    YELLOW CAB Studios
    Paris, France
  • Luke Maslen
    October 31, 2006 at 6:00 am
    Hi Steven,
    Thanks for this information. We’ll run some tests and see if we can replicate what you are seeing.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Andrew Mcleod
    October 31, 2006 at 6:11 am
    Hi Steven
    Please can you send a short example clip to the following email address.
    1 or 2 frames in a motion file then zipped will be suitable.
    pcsupport@blackmagic-design.com.
    The formats I have been using with Nuendo are Uncompressed 8 and 10bit and MJPEG exported from Premiere Pro 2.0. Where did you media originate and what compression rate ?
    Thank You
    Andrew
  • Stevenghouti
    October 31, 2006 at 7:06 pm
    Hi Andrew, one of the files was created on the AVID using PhotoJPEG compression at our request. The other was a PhotoJPEG captured on one of the other Decklink SP PCI-X rigs. With both files playback was blocky on the PCIe video output (both component and composite analog outputs were tested) compared with the onscreen (desktop through Matrox P650 PCIe) display and our other rigs (Decklink SP PCI-X).
    I’m out of the office recording foley all week, but I’ll try to get you some test stuff ASAP.
    Cheers guys,
    Steven
    Steven Ghouti
    YELLOW CAB Studios
    Paris, France
