Activity Forums Blackmagic Design Decklink output while capturing FIXED
  • Decklink output while capturing FIXED
    Posted by Yves De muyter on September 30, 2005 at 6:38 pm
    Hello,
    For people that have the same issues I have seen (Decklink output scrambled while capturing), there is a solution:
    You should modify the Genlock Timing once to some value (I had set it to -128) and click “Apply”. I started premiere once to check if anything changed. After that, you can set it to 0 again. The problem was fixed after that.
    This is with the latest drivers (5.2 on windows), I have no idea if this would be a fix for the older 5.X drivers too.
    -Yves
    Yves De muyter replied 20 years, 11 months ago 1 Member · 1 Reply
  • Yves De muyter
    October 5, 2005 at 7:52 pm
    For people that have this issue, it is only fixed in 5.2 and you have to cycle the settings like described here.
    -Yves
