Decklink not working with Shuttle motherboards ?
Hi all,
I’m having trouble with a BlackMagic card (Decklink Extreme PCIe).
I have recently bought a Shuttle mini PC (SX58H7 with a core i7 proc) and installed Windows Seven 64 bits on it. This buddy runs fine and is quite fast. I updated the bios to the latest version.
The problem is .. if I connect the Decklink card to one of the two PCIe slots in the computer, it won’t start up. The fan will start blowing but nothing will happen (black screen, doesn’t even get to the bios settings)
Have any of you run into anything similar ? I tested the card and it works ok with another computer (a dell running XP 32bits). Would that be due to Windows 7 ? to the 64 bits ? I guess if it was that, it would at least startup ..
thanks for your help
Cyril
