Activity Forums Blackmagic Design Decklink Mini: Pink & Green Lines
  • Decklink Mini: Pink & Green Lines
    Posted by Milton Whitaker on December 18, 2016 at 12:19 pm
    Hi all,
    I’ve been experiencing this issue for quite some time, where I’m using the Decklink Mini for days with no problem then all of a sudden the screen turns pink and green with horizontal lines (unfortunately I didn’t take a pic). I’ve read about people having color space issues, but this is not the case. I believe its a driver because when I restart the machine, the problem goes away. I’m running Premiere Pro, After Effects, Media Composer, Resolve and Fusion on Windows 10 with the latest BM drivers. As a side note, at my job we have 2 Mac Pros, each with Ultrastudio Mini Monitors that experience the exact same problem. Since those are Thunderbolt, we simply unplug and reconnect and the problem is solved. Since the Decklink is PCIE, here are my questions:
    Is there a way to reset the Decklink Mini without restart the entire machine?
    Has anyone experienced this problem and if so, is there a fix?
    MJ Whitaker
    Motion Designer / Visual FX Artist
    Milton Whitaker replied 9 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
