Activity Forums Apple Final Cut Pro Legacy Decklink HD problems… frames freezing
  • Decklink HD problems… frames freezing
    Posted by Armen Grigorian on May 29, 2005 at 8:39 am
    forgive me for posting in multiple forums, but we are in a bind for a solution. any help is appreciated.
    We are onlining our first HD project cut in FCP 4.5 with the following specs and are experiencing some problems. Any help would be greatly appreciated.
    -FCP 4.5
    -G5/Dual 2.7GHz
    -OS 10.4.1
    -Decklink HD card
    -Decklink 4.8 Drivers
    -Digitizing HD-SDI from a Sony JH3 deck.
    -XServe RAID with pre-fetch set to 128MB
    The problem we were initially experiencing was broken timecode. Almost every clip would capture fine until the end of the clip was reached. An error message would then come up regarding broken timecode and the media was ultimately not captured. When the deck control preset for the Decklink card was changed to read both LTC and VITC, the clips captured fine. We subsequently started experiencing problem with random clips that would play and then freeze on one frame only to pick up playing again a few seconds later with the remaining footage that was 2 seconds downstream in the media (i.e. the footage did not pick up on the frame after the freeze frame but where the play marker was in the master clip). This problem is seen even when the captured clips are played back with the Quicktime Player and not FCP. Stepping through the clip frame by frame shows the freeze frames as well as the observed jump to the motion frame downstream (i.e. stepping through and removing throughput as a variable still shows the same problem). This problem is observed with clips being batched for a specific sequence as well as brand new logged clips. Has anybody ever seen this problem and is there a workaround for the problem? Any help would be greatly appreciated as we are on a critical deadline.
    Walter Biscardi replied 21 years, 3 months ago 2 Members · 1 Reply
  • Walter Biscardi
    May 29, 2005 at 11:12 am
    Not a whole lot of help here, but were you running ok with OS 10.3.8 and FCP 4.5? I’ve found FCP 4.5 to be rock solid stable with OS 10.3.8 and have recommended to folks I know to stay at that OS unless you want to move to FCP 5.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
