Activity Forums Blackmagic Design Decklink HD – problem with Snow Leopard or FCS3?
  • Decklink HD – problem with Snow Leopard or FCS3?
    Posted by Tad Newberry on August 14, 2010 at 4:24 pm
    I just did a system upgrade to Snow Leopard and FCS3, and worked on a new FCP project where all files had been converted to ProRes. Went into an older project where there was a mix of codecs, and FCP crashed several times saying there was some conflict with a piece of the BlackMagic software (if it happens again i’ll write down the exact wording). Also, going into System Preferences and selecting Decklink i get this, “To use the “Blackmagic DeckLink” preferences pane, System Preferences must quit and reopen,” which it does, then opens fine, but i don’t recall it ever doing that before.
    Does this sound familiar to anyone?
    thanks for helping out a bonehead!
    __________________________
    2.66 GHz Quad-Core Mac Pro
    3GB RAM
    NVIDIA GeForce GT 120
    …and a few TerraBytes o’ storage
    Aristides Tiropolis replied 16 years ago 3 Members · 2 Replies
  • Kristian Lam
    August 16, 2010 at 10:33 pm
    Hi Tad,
    What version of drivers do you have installed? If you let the System Preferences quit and restart, you should be able to see the version of Blackmagic drivers you’re using at the top of the Blackmagic preference pane window. The preference pane will also tell you which specific model of capture card you’re using.
    From what you’re describing, it sounds like you’re using an older driver that was released before Snow Leopard.
    regards
    Kristian Lam
    Blackmagic Design
  • Aristides Tiropolis
    August 25, 2010 at 5:51 pm
    This happens when a preference pane is 32bit only. When it reopens, does it say: Blackmagic bla bla 32bit?
