Activity Forums Blackmagic Design decklink HD pro is driving me crazy
  • decklink HD pro is driving me crazy
    Posted by Florian Herweg on April 30, 2007 at 6:17 pm
    hi
    freezed external video output
    sorry for repsoting … but i was dealing with that issue the whole weekend (researching and trying) and still cant figure it out!
    so…i got a dvcproHD 23.98 fps timeline … and my output is on the breakout cable … rgb goes into my sony PVM-20M2U broadcast monitor … as well as the worldclock output … i see the picture on my monitor and when i playback the canvas plays normally but i just see a still image on the broadcast monitor … when i hit stop it updated the picture …
    my output setting is blackmagic ntsc 8bit
    regular ntsc sd footage works perfectly
    and yes show all frames is marked and the canvas size is set to fit to window!!!
    i’m really really desperate and could use some help!
    thanks a bunch!
    best
    flow
    Kristian Lam replied 19 years, 4 months ago 2 Members · 1 Reply
  • Kristian Lam
    May 1, 2007 at 7:46 am
    DVCPRO HD 720p23.98?
    We don’t support down conversion from this format, only 720p59.94. However, a customer that I was speaking to said it’s possible using a workaround which I’m investigating. Drop me an email at:
    support[at]blackmagic-design.com
    I’m going to check this workaround out and if it’s ok, let me you know.
    regards
    Kristian Lam
    Blackmagic Design
