Activity › Forums › Blackmagic Design › Decklink HD Pro Dual Setup: RGB out Analog Monitor is very green – Why?
  • Decklink HD Pro Dual Setup: RGB out Analog Monitor is very green – Why?
    Posted by Portland Animator on December 3, 2005 at 5:42 am
    I have the following Setup:
    Dual G5 1.8MHZ, 6.5GB RAM (8 slots)
    Dual Channel HD Pro card in Slot 4 (133mhz)
    FCP HD 5.0.3
    Sony 14″ PVM-14N6U Broadcast Monitor
    Dual 22″ Cinema LCDs.
    I just got this card, I am working mostly in TV resolution right now, so I hooked it up to my Component analog monitor up for the first time. I put the I started a test project, grabbed some NTSC video, and threw it out to the BlackMagic Deck on the NTSC 10 or 8 bit bit settings I get a picture, but its very green. My monitor will either take external sync or sync on green, whih it currently is. (external video set to NTSC RGB, I get nothing, black screen)
    This green look also occures in the extended Desktop.
    Any ideas what Im doing wrong?
    Ed Anderson
    Animator
    ed@animationpdx.com
    Luke Maslen replied 20 years, 9 months ago 2 Members · 2 Replies
  • Portland Animator
    December 3, 2005 at 5:57 am
    I figured it out. 5 minutes later- I had failed to enable the 4:4:4 Dual output in the BlackMagic Systme prefs. I would have assumed they would be on by default, but I guess not.
    Thanks anyway!!
    Ed Anderson
    Animator
    ed@animationpdx.com
  • Luke Maslen
    December 6, 2005 at 5:22 am
    Hi Ed,
    I’m glad you figured that out and it is an easy preference to overlook.
    Video output can appear rather pink and green if you are working in 4:2:2 mode but the 4:4:4 checkbox is enabled.
    Video output can also appear rather pink and green if you are working in 4:4:4 mode but the 4:4:4 checkbox is disabled.
    Finally, when using a multiformat monitor with component analog video input, it is necessary to use the monitor’s menu system to switch between:
