Activity Forums Blackmagic Design decklink hd – monitoring embedded audio during capture?
  • decklink hd – monitoring embedded audio during capture?
    Posted by Dieter Heinz on July 9, 2011 at 12:59 pm
    Hey guys.
    I hope that maybe an owner of the Decklink HD extreme card might answer this question:
    While capturing HD-SDI with embedded audio with Final Cut Pro, will I have the possibility to monitor the 8 audio channels on the analog output of the card? If so, how does the downmix work? Is there any influence of the version of card or firmware on this function?
    I don´t have this card here, so I kindly ask for your help.
    Thanks in advance!
    KH
    Dieter Heinz replied 15 years, 1 month ago 1 Member · 1 Reply
  • Dieter Heinz
    July 13, 2011 at 12:32 pm
    Hey guys.
    So I´ll answer to this myself as the Blackmagic support ist quite fast and competent!
    Except for some very old versions of the card this function works.
    Bye,
    K
