Activity Forums Blackmagic Design Decklink HD extreme with Media Composer 6 – hardware crippling the AVID?
  • Decklink HD extreme with Media Composer 6 – hardware crippling the AVID?
    Posted by Chris Oben on August 5, 2012 at 12:52 am
    Created an MC6 project: 1080p/25
    When I select the project to load it, MC6 hangs and gives me an error message:
    AMEResourceManager::ReconfigHW_LegendBoB_play()
    Error [2147483656] unable to:
    SetVideoFormatBlk.
    This system has a BlackMagic Decklink HD Extreme for HDSDI monitoring.
    Any suggestions. I do not need the video out for this project. Is there a way to disable the hardware output of MC?
    Chris M. Oben
    Chris M. Oben
    https://www.chrisoben.com
    Ken Evans replied 14 years ago 3 Members · 4 Replies
  • Richard Lapthorn
    August 23, 2012 at 11:30 am
    Hi Chris,
    Which version of MC6 are you using and which version of the Blackmagic drivers?
    The latest update to MC6 allows you to switch off hardware support, however what you are describing doesn’t sound normal and I reckon should be fixable
  • Ken Evans
    August 30, 2012 at 11:32 am
    Hi I’m having some Avid issues regards this problem. How do you turn off the hardware support from within MC6?
    Senior Technician, Moving Image Department – Kingston University London.
  • Richard Lapthorn
    August 30, 2012 at 2:05 pm
    Hi Ken, the latest Avid update 6.03 allows you to easily switch between hardware and software modes.
  • Ken Evans
    August 30, 2012 at 6:17 pm
    Yes but where is this within the app?!
    K.
