Activity Forums Apple Final Cut Pro Legacy Decklink HD Extreme- Sync HDMI monitor
  • Decklink HD Extreme- Sync HDMI monitor
    Posted by Edward Howard on July 28, 2009 at 9:13 am
    I’m having a problem with syncing my external HDMI monitor (Haspree 28″ full HD) with my computer monitors.
    I’ve played with the frame offset (6 frames working with 24fps) so the pictures match but now the audio is out of sync because it is not affected by the frame offset.
    The audio is going from the balanced outputs of the card to some ESI speakers. I’ve also noticed that the audio from the HD display is at same time as the audio from the speakers.
    Looking through the FCP manual it mentiones lactency issues like this should be fixed using audio drivers provided by the card manufactuer.
    I’ve got the latest fireware on the card, I’ve looked everywhere on the forum and the web, I can’t find setting in OS X or the Decklink control panel that allows me to adjust the audio latency.
    I’d really appreciate any light anyone can shed on this.
    Thanks for reading and all the best.
    Ed Howard
    https://www.visual-carnival.co.uk
    Mac Pro 8 core, 2.26Ghz, 6GB RAM, 650GB, 2.2TB G-Speed RAID 5, Decklink HD Extreme, ESI nEar 05,
    Edward Howard replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
