Activity Forums Blackmagic Design Decklink HD Extreme downconvert from HD to SD
  • Decklink HD Extreme downconvert from HD to SD
    Posted by Joe Trepanier on January 18, 2007 at 2:25 pm
    Hi all,
    I was wondering if anybody could tell does the Decklink HD Extreme downconvert from HD to SD in realtime? I’ve looked around but can’t find this info.
    cheers,
    Joe
    Joe Trepanier replied 19 years, 8 months ago 4 Members · 5 Replies
  • Bill Buchanan
    January 19, 2007 at 8:40 pm
    I wish someone would respond to your question. I’d like to know myself.
    Bill Buchanan
    Buchanan Film Co.
  • Kristian Lam
    January 21, 2007 at 10:51 pm
    Yes, the DeckLink HD Extreme will downconvert from HD to SD using software down conversion.
    1080i50 will down convert to PAL.
    1080i59.94 will down convert to NTSC.
    1080p23.98 down converts to NTSC if it is played out with 3:2 pulldown as 1080i59.94.
    720p59.94 down converts to NTSC.
    regards
    Kristian Lam
    Blackmagic Design
  • Joe Trepanier
    January 22, 2007 at 2:09 pm
    Hi Kristian,
    Thanks for the info. You wrote that it’s done using software down conversion…does that means it needs to be rendered and thus not realtime?
    cheers,
    Joe
  • Aaron Neitz
    January 22, 2007 at 5:03 pm
    Oh it’s realtime… But here’s the lowdown: it’s not very good. Rather soft image – and only the anamorphic setting looks ok, the letterbox is terrible.
    However, it’s a great timesaver if you need a quick SD dub make from HD. And it totally works without hassles or hiccups.
  • Joe Trepanier
    January 23, 2007 at 6:54 pm
    Thanks Charlie.
    Joe
