Activity Forums Blackmagic Design DeckLink HD Extreme 3D up converting
  • DeckLink HD Extreme 3D up converting
    Posted by Javier Sanchez on January 6, 2011 at 1:16 am
    Hello we have a URSA telecine SD wich is being captured by the new DeckLink HD Extreme 3D plus, what i want to know is, if i select the blowup option to HD what is the card doing with the SD signal?
    Searching for a complex answer but i didn’t found any…
    Regards
    Javier Sanchez replied 15 years, 7 months ago 2 Members · 4 Replies
  • Shane Ross
    January 6, 2011 at 2:53 am
    The hardware is scaling the footage. Are you looking for the engineering specs on what EXACTLY it is doing? I don’t think they are out there.
    Shane
  • Javier Sanchez
    January 6, 2011 at 3:06 am
    Yes in fact i’m looking for the engineering specs to explain my clients thats it’s quite a good option.
    Regards
  • Shane Ross
    January 6, 2011 at 3:56 am
    Will your clients understand the specifications if you told them? My producer glazes over when I talk about what I need to do to get codecs to match. I just say “hardware is better…it just is.”
    Shane
  • Javier Sanchez
    January 6, 2011 at 12:53 pm
    Yes sure but you know there is always a client who know everythink, Thats why. Last time i client cause me problems because i didn’t give him R3d archives colored in 4k i had to explain him that he didn’t need it for Tv comercial thats why i gave him hd 10bit uncompress. But he discuss with me about the color information….
    So thats why i need to know, cause there is always a client who want to be clever than you…
