Activity Forums Blackmagic Design Decklink HD Extreme 3D+ don’t gives external preview in play in Final Cut
  • Decklink HD Extreme 3D+ don’t gives external preview in play in Final Cut
    Posted by Ezany Brandão on September 25, 2011 at 12:03 am
    Hi evebody.
    My Decklink Extreme show preview in a external broadcast monitor when the cursor is stoped, but when is playing the external preview continue stoped and just refresh the frame when I stop the play in timeline.
    Can anybody help me please?
    Ezany Brandão replied 14 years, 11 months ago 3 Members · 3 Replies
  • Paul Jay
    September 26, 2011 at 2:44 pm
    Match your Video Playback settings to your Sequence settings.
    What is your Sequence?
    What is your Video Playback Setting?
  • Joshua Helling
    September 28, 2011 at 5:37 pm
    Yup, that type of issue is normally a file/sequence mismatch.
    As Paul says, make sure the Sequence settings and Playback settings match. The easiest way to do this is to take a look at the file you wanna use. Find the Blackmagic Easy Setup that matches frame size/rate and codec of the file. Then use that easy setup (start a new sequence) and it should work.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Ezany Brandão
    September 29, 2011 at 4:06 pm
    Hey guys. Thank you for you helpe.
    Yes, my timeline mach is correct. Is exact the same features of my video in play. But I discovered part of the problem.
    To get a external play preview I needed set the timeline codec to the Blackmagic native. This solve the problem of external play, but I need to make a render preview every time in all files to get this.
    Today, the most of time, the video files that come for me, is from a card and normally the app transfer just convert for the native codecs or Apple proress code. Today, no one more use capture image from a type. So when I go tranfers my files from cards (XDCAM TRANSFER, LOG AND TRANSFER e etc) I have no option of the BlackMagic codec. I just can chosse native or apple proress. So if I need to make a render preview every time I’ll lost much time.
    Is there some solution for this or will I always need to make a render preview?
    Thank you again.
    Sorry my inglehs
