Activity Forums Blackmagic Design DeckLink HD Extreme 3D+ disk requirements for compressed capture?
  • DeckLink HD Extreme 3D+ disk requirements for compressed capture?
    Posted by Aaron Pulicano on February 12, 2012 at 7:05 pm
    First off, is it possible to record just the audio stream from an HDMI source with video+audio streams? If not, what are the disk speed requirements for compressed video capture with uncompressed six or eight LPCM of 1920x1080p59.94 and 1280x1470p59.94 video? I do not care how bad the video looks to be honest (I would want to use lowest bit-rate setting possible for video) as long as the audio portion remains at full quality.
    Also, does the DeckLink HD Extreme 3D+ work with adobe premiere or virtualdub? If so, are additional compressed codecs available while still having the ability to support for up to eight channel LPCM?
    This is the hard-drive I have. Would it be enough for what I outlined above? If not, please recommend one.
    https://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
    CPU is an AMD Phenom II X4 720 @ 3.5Ghz (X3 720 with unlocked 4th core)
    With 8GB of DDR2 1066Mhz memory.
    Aaron Pulicano replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
