Decklink HD Extreme 3 and h.264 pro recorder in one system
I need to use a MacPro which has a Decklink HD Extreme 3 installed. Can I also attach via USB a H.264 Pro Recorder to the same system?
If so, and I fire up Media Express, which device will it capture from?
I’d like to use the Decklink HD Extreme 3 for general FCP work and the Pro Recorder whenever I need fast H.264 captures for client previews.
Also, is the Decklink HD Extreme 3 the same as the Decklink HD Extreme 3D or are these physically different cards.
And, what’s the minimum MacOSX for the Media Express software? I’m on 10.4.11 will it run?
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
