Activity Forums Blackmagic Design Decklink HD and AJA IO LA
  • Decklink HD and AJA IO LA
    Posted by Damon Surzyshyn on May 24, 2005 at 7:09 pm
    Has anyone used this setup…seems like a much more cost effective solution than the AJA IO LA/Kona 2 Setup. Any idea if the drivers conflict?
    Damon Surzyshyn
    Sean Oneil replied 21 years, 4 months ago 2 Members · 1 Reply
  • Sean Oneil
    May 26, 2005 at 3:32 pm
    The AJA IO works through the firewire port. One normally wouldn’t need a Decklink or a Kona with it. However, I think the IO is neat how it works over firewire and all, but you can get almost everything the IO offers with a Decklink Extreme by itself. And you won’t have to waste your firewire bandwidth. I’d reccomend the IO fo someone with a Powerbook or a MacMini. If you have PCI-X slots, use them instead.
