Activity › Forums › Apple Final Cut Pro Legacy › Decklink HD 3D & SDi 2…
  • Decklink HD 3D & SDi 2…
    Posted by Eric Johnson on October 18, 2011 at 5:42 pm
    So I posted this on the Black Magic Forum with no help…. I’m hoping someone here has an idea. Thanks.
    Hi there, new to the Black Magic products and I’m having some issues getting a signal out of the SDi 2 for my playback.
    I am used to the Kona’s. Where it is possible to have an output strictly dedicated to your permanent setup, like monitor and scopes for color correction and general editing work, and another for things that may change depending on the job, decks, etc…
    As of right now I can not get anything to come out of my SDi 2. And I can’t tell if if it’s something I need to set up or have disabled…. the control panel/pref pane doesn’t really come across as user friendly as the AJA Control Panel…
    Any thoughts would be supremely helpful. Thanks.
    Eric Johnson replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
