Activity › Forums › Blackmagic Design › Decklink + Graphic Card?
Posted by Diogo Valente on November 29, 2007 at 2:59 pmHello everyone, I
Kristian Lam replied 18 years, 9 months ago 2 Members · 3 Replies -
Kristian Lam
November 29, 2007 at 11:53 pmHi Diogo,
You can certainly use the DeckLink card + 2 other monitors. The type of card you’ll need will depend on what kind of tv you will be using as the connection type varies. However, I would recommend the DeckLink HD Extreme as a starting baseline as that will output SDI and analog in both SD and HD.
regards
Kristian Lam
Blackmagic Design -
Diogo Valente
November 30, 2007 at 11:05 amThank you Kristian for your quick response.
Also, Do you know if I can use the decklink card in Win XP 64Bits environment?
I ask you this because I will power up the new system with 8Gb of RAM. Since most of my work is done in after effects I will probably benefit from that.Last question (I promise!) I’m considering the Nvidia Quadro FX 1500 (I think this card will be sufficient for my needs), is there any issues that you know of, between this card and Decklink HD Extreme?
Regards
Diogo -
Kristian Lam
December 2, 2007 at 11:39 pmHi,
Yes, the card will also work in a 64-bit Windows environment. Just use the right drivers that correspond to your operating system (32 or 64 bit).
I’m not aware of any issues with Nvidia cards.
regards
Kristian Lam
Blackmagic Design
