Activity Forums Blackmagic Design DeckLink for Windows V5.1.2 now available
  • Oscar G.
    August 25, 2005 at 2:33 pm
    hy.
    Realase works fine!
    what about the title module of PPRO… still not real time, even in black magic dv mode…
    Regards
    Oscar
  • Holger
    August 25, 2005 at 5:18 pm
    Is the problem with PAL DV-Clips realy fixed? In the Caveats on the decklink-Supportsite is “DV Clips look weird” already written?
    And is this only fixed for PremierePro, or for Vegas too?
    hs
  • Yves De muyter
    August 26, 2005 at 8:05 am
    Hello,
    I have tried this version. It is definitely an improvement. Lowerfield DV plays out the decklink with the right field order. You can now capture DV lowerfield, edit it and export it to tape again without creating a sub-project and reversing field order.
    NOT FIXED:
    Of lesser importance of the above, the decklink shows garbage on its analog output when recording. As soon as the record-window is active, the decklink should show its input. Right now, it shows a field shifted down approx 1/5 of the image and the other field shifted down approx 2/5 of the image, resulting in a funny flickering image. I tried recording it once (looping the decklink output to another decklink system) but of course it cannot lock on such video.
    This seems to be ONLY on the composite AND component output. SDI output is OK (but hooked up to the deck).
    NOT FIXED:
    When creating our own preset to record DV in upperfield, it still records in lowerfield. Premiere has everything right for FX to do upperfield DV, only BMD seems to have problems.
    System:
    HP wx8000
    DeckLink Extreme
    Drivers: 5.1.2
    -Yves
  • Holger
    August 26, 2005 at 8:30 am
    Thanks Yves for the informationen about PremierePro. Anyone here who is using Vegas, ist this Problem fixed there too?
    hs
