Activity Forums Blackmagic Design Decklink extreme w/ G4 FW800
  • Decklink extreme w/ G4 FW800
    Posted by Kurt Porter on January 10, 2006 at 10:12 pm
    On a budget here and need a card with both component and SDI. Decklink Extreme seems to be the best bet. However, I only have a G4 FW800 to put it in. A Promax salesman advised me against it and said they wouldn’t recommend it for a G4 and wouldn’t even sell it to me. Maybe they’re just being cautious…
    Has anyone used a Decklink Extreme with a FW800 before and if so were there any problems?
    Upgrading to a G5 isn’t in the budget right now.
    Kurt
    Luke Maslen replied 20 years, 7 months ago 2 Members · 1 Reply
  • Luke Maslen
    January 12, 2006 at 6:55 am
    Hi Kurt,
    If you are running Mac OS X 10.3.8 and FCP 4.5, then any G4/800 MHz dual processor or faster will be fine with the DeckLink Extreme. If you are running Mac OS X 10.4.3 and FCP 5, then a dual processor G4/1.25 GHz or faster will be fine with the DeckLink Extreme.
    The FW800 drive might or might not be fast enough for uncompressed 10-bit capture. It would probably be fine for 8-bit uncompressed or alternatively you could capture in any of the DV, DV50 or PhotoJPEG formats.
    Regards,
    Luke Maslen
    Blackmagic Design
