Activity Forums Blackmagic Design Decklink Extreme to SRW-5800 drift problems
  • Decklink Extreme to SRW-5800 drift problems
    Posted by Kevin Johnson on March 24, 2009 at 5:15 pm
    I have a 720p 8 bit sequence I am trying to output to the SR deck at 720p. The insert hits the edit point, however by the time bars and tone are done, my slate has drifted 4 frames. I’m using the Decklink 720p 8bit easy setup. Is there a way to adjust for this?
    Any help would be greatly appreciated. Deadline is approaching!
    Kevin
    FCP Editor
    Washington, DC
    Kevin Johnson replied 17 years, 3 months ago 1 Member · 1 Reply
  • Kevin Johnson
    March 24, 2009 at 6:07 pm
    I also had the exact same problem on our D5 deck. Do I need to adjust the frame offset control in a/v settings?
    FCP Editor
    Washington, DC
