Activity › Forums › Blackmagic Design › Decklink Extreme SDI Video Flickers
  • Decklink Extreme SDI Video Flickers
    Posted by Jeff Anderson on April 27, 2005 at 8:26 pm
    I am having a problem with the Decklink Extreme SDI output flickering when it is input into our Sony DSR-1500A VTR. I have tried inputing a reference to the 1500A and going without but it makes little difference. Also, I have changed the reference setting from standard to non-standard but there is no change. The analog outputs look great. Do you have any ideas what is causing the flickering?
    MB – Supermicro P4SCT+II
    CPU – P4 3.4
    RAM – 2GB
    OS Win XP SP2
    Video – Matrox Parhelia with dual LCD monitors
    Boot HDD – WD 7200 RPM
    Video array – Stripe set of 4 x 250 GB SATA HDD with Promise FastTrak S150 SX4 RAID controller
    Video Capture – Decklink Extreme v4.8.1
    Video Editor – Adobe Premiere v1.5
    Luke Maslen replied 21 years, 5 months ago 2 Members · 2 Replies
  • Jeff Anderson
    April 27, 2005 at 10:26 pm
    I have solved the problem. I had to adjust the sync timing (H-Phase) on the DSR-1500 and the SDI video input no longer flickers.
    Jeff Anderson
  • Luke Maslen
    April 28, 2005 at 2:25 am
    Hi Jeff,
    Thank you for posting both the problem and the solution. That is very useful information for other DSR-1500 users.
    Regards,
    Luke Maslen
    Blackmagic Design
