Activity Forums Blackmagic Design Decklink Extreme PCI + Vista 64 + 4G ram
  • Decklink Extreme PCI + Vista 64 + 4G ram
    Posted by Yasser Amin on February 12, 2009 at 1:26 pm
    Hi
    Is there a solution to let Decklink Extreme PCI to work under Vista 64 with 4G ram ?
    No output or working premiere Time line until reduce the memory to 2G ram
    thanks
    Thomas Madroszkiewicz replied 17 years, 5 months ago 3 Members · 6 Replies
  • Thomas Madroszkiewicz
    April 16, 2009 at 1:46 pm
    Hey Yasser!
    I’m having the same problem now.
    I tried almost everything. Even contacted Blackmagic but there were no answer.
    Vista x64 Ultimate + Tyan Thunder K8WE mobo + Declink Extreme PCI + 4gB kingston ECC RAM. And the card works only if I remove 2GB of ram.
    Do you get some help with this.. or you changed to Vista 32??
    Cheers,
    Thomas
  • Yasser Amin
    April 16, 2009 at 9:42 pm
    Hello Thomas
    No way to get Decklink PCI working under XP or Vista 64 with 4G ram
    I switched to Vista 32 with CS4 and last driver 7.1 and every thing working stable
    regards
    Yasser
  • Kristian Lam
    April 16, 2009 at 11:58 pm
    The PCI version of DeckLink Extreme will not work with more than 2 Gb of RAM, only the PCIe version.
    regards
    Kristian Lam
    Blackmagic Design
    April 17, 2009 at 7:53 am
    Thanks for the answers. Really bad news although.
    Is there any chance for some kind of firmware update to this card or I should change for something else.
  • Yasser Amin
    April 18, 2009 at 12:36 pm
    any firmware update for Decklink cards is integrated in the driver
    April 20, 2009 at 8:59 am
    Great.
    Just wondering why Blackmagic not mentioning this issue on their site.
    They even write in Decklink minimum system requirements Windows Vista recommended 4GB ram.
    I did not find any clue on this in the support section.
    or maybe a red-white banner..
    “FOLKS DON’T BUY THIS CARD IF YOU USE MORE THAN 2GB RAM”
    Now I have two options throw away 2x1gb Kingston ECC RAMS.. or sell somehow Decklink Extreme PCI and buy PCIe version. 🙁
    Anyway…thanks for the help everyone. 🙂
