Activity › Forums › Blackmagic Design › Decklink Extreme on Pci 32 bits Windows?
Posted by Manololp on May 11, 2005 at 8:34 pmHello. My question: it works the DL Extreme on a motherboard with 32 bits Pci (915, 925, 955 Intel chipsets or Nvidia nforce 4)?
The blackmagic website “recommend” 64 bits slot but is NOT strictly forbid to use 32 bits slot.
Please, any experiences?
Thanks in advance.
Manuel LopezFrancisco Rubiales replied 21 years, 4 months ago 4 Members · 6 Replies -
Yves De muyter
May 13, 2005 at 5:41 amFor simple playing back purposes, this works OK. For recording or Premiere support, it does not work at all.
-Yves
Markh
May 14, 2005 at 11:32 amDoes it help to have 2x250GB SATA drives in a Raid 0 configuration? Or were you already referring to using Raid?
Yves De muyter
May 14, 2005 at 4:31 pmNo. PCI bandwidth is the bottleneck, not the disk IO. Allready tried using an adaptec 39320 in a 32-bit PCI slot. DeckLinks should be in 64-bit slots for NLE purposes. For simpler things (like keying graphics over live), 32-bit is okay.
-Yves
Francisco Rubiales
May 14, 2005 at 5:42 pmHi Manolo, Mark and Yves.
Yves said:
“For recording or Premiere support, it does not work at all.”
and then said:
“For simpler things (like keying graphics over live), 32-bit is okay.”
Could you clear this out please?
Does this means you can capture from a deck, and then output and record to same deck, a simple stream with maybe some titles?
That for me is simple things. Can you do that with Decklink in a 32-bit slot and a Raid?
Paco.
Yves De muyter
May 15, 2005 at 1:08 pmNo.
Like I said: capturing won’t work reliably on 32bits.
Simple playback seemed to work on older drivers. I haven’t tested this on 4.8 yet.What does work is the livekey application.
-Yves
Francisco Rubiales
May 16, 2005 at 4:25 amOk, thanks for the valuable info Yves.
Cheers to all.
Paco.
