Activity Forums Blackmagic Design Decklink Extreme Help please.
  • Decklink Extreme Help please.
    Posted by Peter Mackay on July 1, 2005 at 2:44 am
    For a long time I did not have to feed my Beta SP deck from FCP so I had the Y connector from Decklink component video out going to my Sony Monitor, all was well. But now I have the need to master to the deck and have re-routed the component video to the deck video in. When I work in FC I can monitor the video through the deck, so far no problem. Same with AE, monitoring NTSC works fine. However when I try to view and image from photoshop on the monitor it does not work. In fact the export dialog box says that there is no device connected. How are others feeding their Monitors when you also have to connect the deck with component.
    Peter Mackay replied 20 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
