Activity Forums Blackmagic Design decklink extreme hdmi monitor output, sd project
  • decklink extreme hdmi monitor output, sd project
    Posted by Paul Toth on March 29, 2010 at 6:56 pm
    Hi
    I use the Extreme HD card (which has been excellent btw) however I have run into an interesting problem.
    When I output SD timelines (which look good on the betacam deck so no issue there) the HDMI monitor (1920×1080 24″ Acer) shows the SD picture with a bunch of vertical lines and odd color – washed out a bit, light purple skin tones, blue shows as light green – and the 4×3 image is stretched out 16×9.
    Again, it outputs to the beta deck properly just not to the HDMI monitor. HD projects output correctly. I am using PPro CS4.
    Thoughts?
    Paul
    Paul Toth replied 16 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
