Activity › Forums › Blackmagic Design › Decklink Extreme HD-SDI and HDMI simultaneously
  • Decklink Extreme HD-SDI and HDMI simultaneously
    Posted by Neil Sadwelkar on November 6, 2010 at 10:05 am
    With the new Decklink HD Extreme 3D can I get video (and embedded audio) out over HD-SDI and simultaneously over HDMI as well?
    Further, can I route the embedded audio (6-8 tracks) through HDMI so that I could use a professional HD-SDI monitor for video and a home theatre with HDMI input for the 6-track audio?
    Should be possible as the manual for Decklink says (pg 46)…
    “This example shows DeckLink HD Extreme 3D connected to a Sony HDCAM SR series digital deck in 4:2:2 HD mode for capture and playback to the HD-SDI deck. The HDMI, spare SDI and component analog outputs can be used for local monitoring of 4:2:2 HD video.”
    Anyone connect it this way?
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
    Pablo Nóbrega replied 15 years, 5 months ago 2 Members · 1 Reply
  • Pablo Nóbrega
    May 2, 2011 at 1:19 pm
    I really would like to know the same!! I thank you if you have the answer… Saludos.
