Activity › Forums › Blackmagic Design › Decklink Extreme HD not seen by Mac Pro
  • Decklink Extreme HD not seen by Mac Pro
    Posted by Noah Kadner on September 13, 2006 at 2:03 am
    Mac Pro Quad core 3Ghz Xeon, 5 GB Ram, 4 Internal drives(system + 3 750 GB extras). Running all latest software updates, etc. System was working fine with FCP for about two hours. Then we restarted- now Decklink doesn’t show up at all. Tried running Slot Utility- shows up there but then does not appear to FCP, Profiler or System Prefs. Any help greatly appreciated.
    -Noah
    Noah Kadner replied 20 years ago 2 Members · 4 Replies
  • Luke Maslen
    September 13, 2006 at 3:52 am
    Hi Noah,
    Can you please try the DeckLink card in slot 4 (top slot) and select the second profile from the Expansion Slot Utility. That might help but it does seem odd that it was working fine and then “disappeared”. Did anything about the software or hardware configuration of your Mac change between the time all was working fine and when it stopped working?
    Regards,
    Luke Maslen
    Blackmagic Design
  • Noah Kadner
    September 13, 2006 at 4:15 am
    Thanks Luke- we managed to figure it out. A PRAM reset with command-option P R did the trick. It also cleared up an odd graphical glitch displayed during startup. This is a brand new machine BTW.
    Noah
  • Luke Maslen
    September 13, 2006 at 4:46 am
    Hi Noah,
    Thank you very much for posting your solution. That was a weird problem which I hadn’t struck before so it’s great that you’ve posted the solution here in case anyone else encounters a similar problem.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Noah Kadner
    September 13, 2006 at 3:47 pm
    Sure no problem- it works like a charm.
    Noah
