Activity › Forums › Blackmagic Design › DeckLink Extreme drop frame
  • DeckLink Extreme drop frame
    Posted by Lilei on June 10, 2005 at 1:46 am
    drop frame
    Hardware environment:
    Power Mac G5 double 2.5G
    Memory:2.5G
    Decklink Extreme
    ATTO UL4D SCSI
    1.6T MediaVault U320-S/Dual
    software environment
    Luke Maslen replied 21 years, 3 months ago 2 Members · 1 Reply
  • Luke Maslen
    June 10, 2005 at 7:32 am
    Try using a DV or JPEG easy setup and see if the problem goes away. If the problem goes away, then it is a disk-related problem even though the speed tests show that your disk array is very fast.
    Which cards to you have in which PCI-X slots? For example, is the DeckLink Extreme is slot 2 and the ATTO UL4D in slot 4?
    Can you provide more detail about what you do when you are performing “delicate editing”?
    Regards,
    Luke Maslen
    Blackmagic Design
