Activity › Forums › Blackmagic Design › Decklink Extreme… Can i see the video during capturing on video monitor ?
  • Decklink Extreme… Can i see the video during capturing on video monitor ?
    Posted by Ozcool on March 16, 2006 at 10:25 pm
    While capturing with premiere pro2 i see a green screen on my video monitor….
    my computer monitor is okey.. i see the video… do i need to set something ?
    Thanks..
    best regards..
    Ozcool replied 20 years, 6 months ago 3 Members · 3 Replies
  • Shane Chadder
    March 17, 2006 at 1:02 am
    Hi
    Check your decklink settings in the control panel. If you set decklink to output black while you are capturing you can’t monitor while you capture.
    Shane
  • Nikolas
    March 17, 2006 at 5:19 pm
    the best way is looping video signal to monitor so you send your deck signal to monitor and then the monitor output to decklink, so you can see what you capture and when you playback you can see it in the monitor
    its the way i do it
  • Ozcool
    March 19, 2006 at 1:32 am
    Thank you very much Shane and Nikolas…
    best regards…
