Activity Forums Blackmagic Design Decklink Extreme and 4 Channel Audio Output
  • Decklink Extreme and 4 Channel Audio Output
    Posted by Matt Bishop on July 21, 2005 at 2:40 pm
    Hello, I was wondering if anyone had any advice on a 4-channel audio output solution. Here is what I was thinking, and I was curious if this is possible…In FCP 5.0 if I use a Decklink Extreme Card can I output 4 channels of audio via SDI to a Digital Betacam (DVW-500) in a single pass, or do I have to do this in two passes?
    If anyone has any advice it would be greatly apprechiated, thanks.
    Cheers
    Matt
    Olivier Jean replied 21 years, 1 month ago 4 Members · 3 Replies
  • Jason Levy
    July 21, 2005 at 6:36 pm
    Yes, you can do it in one pass. You only have to set up the two extra outputs in FCP in your sequence settings. Works nice.
    jason
  • Nico Sandhof
    July 22, 2005 at 10:24 am
    you can do it also 8 channels in one pass (embedded sdi audio) – analogue audio only 2 channels…
  • Olivier Jean
    July 23, 2005 at 5:06 am
    select your sequence, command 0 to bring up
    your sequence settings, click on the audio outputs tab
    and add 2 extra audio track either as stereo or dual mono
    and you’re done.
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
