Activity Forums Blackmagic Design Decklink DV Playback Problem
  • Decklink DV Playback Problem
    Posted by Timothy Eaton on June 19, 2006 at 10:56 pm
    Using PPro 2.0 with Decklink HD in Decklink/DV mode, timeline sequences play back in the program window and my picture monitor just fine. However, when I play a clip in the source window, video freezes while audio continues to play. This wasn’t an issue in the past. Could a setting have changed?
    Thanks.
    Timothy Eaton replied 20 years, 1 month ago 2 Members · 2 Replies
  • Stefan.shift
    July 20, 2006 at 1:30 pm
    I had a similar situation.
    I then started Premiere 2.0 with shift-key held down.
    This should clean some temporary driver cache or so (Adobe support).
    In my case it helped.
  • Timothy Eaton
    July 21, 2006 at 4:54 am
    Stefan,
    Thanks for the help. I got it working today. Tim
