Activity Forums Blackmagic Design Decklink driver 5.2 drop frames
  • Decklink driver 5.2 drop frames
    Posted by Cuttlefish on November 3, 2005 at 1:15 am
    Hi all,
    I am using a Decklink HD Pro capture card with a RAID0 array to capture 1080i 30 fps. I am using 8 bits. When I ran the Decklink speed test, I get about 150 MB/s for the write and 40 fps for the mode I described. My problem is that when I capture longer than 30 seconds, the decklink card will drop about 50% of the frames. I think the problem is the raid drive can’t catch up with the capture, but Speed test tells me otherwise. Has anyone else seen this problem?
    Kaspar Kallas replied 20 years, 10 months ago 3 Members · 4 Replies
  • Matt Dowling
    November 3, 2005 at 11:08 pm
    150MB/sec for 1080/60 is nowhere near adequate. Our speed disk test is there as a guide, not an absolute. You need to have some overhead – around 20%. for any RAID setup. For 1080/60 a RAID running around 200-220MB/sec would be a good solution.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
  • Cuttlefish
    November 4, 2005 at 2:14 am
    Matt,
    Thanks for the reply. I forgot (not purposely) to mention that using the 4.4b10 drivers the system has no problem capturing at all. I know a lot has changed since 4.4 days, but do you know any change that might have caused this.
  • Matt Dowling
    November 4, 2005 at 2:24 am
    To be honest 4.4 is over a year ago, so much has changed since then that i would have no idea why 4.4 worked and 5.2.2 doesn’t. There has been so many improvements in regards to features and stability since then, i would not recommend running 4.4. There has been a lot of OS changes since then to. That would be the first thing i would look at.
    Regards,
    Matt
    Blackmagic Design
  • Kaspar Kallas
    November 4, 2005 at 9:18 am
    Make sure you do not have more adio channels than you need. If you are on that critical level removing the audio might help.
    -Kaspar
