Activity › Forums › Blackmagic Design › Decklink, CS5 and Mercury
Posted by Derrick on June 13, 2010 at 8:46 pmHi there,
I’m wondering, id you add a decklink card to the system, and use a BMD preset, do you loose the mercury accelerated playback?
In CS4, if I use DVCPROHD presets, I can have 8 720p video tracks stacked ontop of each other, and it plays back smooth,(but obviously nothing goes out through the decklink card)
with a BMD preset I can’t even have two video tracks ontop of each other playback smooth.
anyone tested this, or thought about it?
thanks,
DerrickGeorge Sey replied 16 years, 3 months ago 6 Members · 7 Replies -
Slobodan Milivojevic
June 14, 2010 at 11:40 amBlackmagic settings are working in CS5, but you will notice same problems as in cs4 – in Blackmagic sequnce you will have around 1/3 of Premiere full power…..
Derrick
June 14, 2010 at 2:53 pmso the mercury engine becomes unusable then.
how can yo output to a calibrated broadcast monitor without losing the mercury engine?
– Derrick
Aristides Tiropolis
June 15, 2010 at 1:10 amNot the best thing ever, but here goes:
Do your edit in an adobe preset. You do not need the broadcast monitor for your edit. When finished and for color correction, checking legality (you need the scopes too) or for scene discussion and inspection you can always copy everything in a blackmagic sequence.
It could be a little difficult for BM to bypass the fact that Mercury acceleration happens in the graphics card. So if outputting from the BM Card I guess something’s gotta give. On the other hand it is not clear to me if Mercury acceleration happens as process giving back an accelerated timeline for “everyone” in the system to use, or if it is something meant only for the graphic’s card output. Maybe the BM team can shed some light as to how the API works, or if there is an API to tap into anyway.
Derrick
June 15, 2010 at 8:18 amgood point Aristides,
I suppose you could edit everything as normal, and do your color correcting in a nested BM sequence. would be nice if the acceleration was there though.
– Derrick
Tanel Toomsalu
June 15, 2010 at 10:55 amHello,
Acceleration is definately there, you just get less layers than non-blackmagic project.
I get 2-3 layers or so. Depending on your needs it may be not enough, but it satisfies my needs completely as I rarely have more than 2 layers on the same time.
Im using Decklink Extreme 2, i7 920, gtx285.I hope it helps
Dominic Osborne
June 16, 2010 at 1:18 amI can understand completely why there is the lowering of performance in this case.
I’ve been following the matter closely as I’m about to buy the cS5 suite with HD Extreme III and don’t want a duff setup.
However, it seems that the Aja customers are sufferinng bigger performance losses compared to BM, if you check their forum here.
I hope that as CUDA and GPGPU stuff advances that there can be more data exchange back to the other internal components like BM cards in the future.
Otherwise the solution is probably a Quadro card with SDI output (highly expensive) / some way of taking DVI or Displayport feed from Quadro card and linking from that to broadcast monitor through a converter… but lose a desktop screen in the process (unless you have SLI for extra monitor connections…)
Dominic Osborne
Director & Head of Visuals
Eight Eyed Sea Bass Ltd
http://www.eesb.tv -
George Sey
June 22, 2010 at 12:26 amSo in a nutshell what are the advantages of MPE in a decklink system. Is the card better with BM?
