Activity Forums Blackmagic Design Decklink Control Panel ActiveX
  • Decklink Control Panel ActiveX
    Posted by Warren James on June 15, 2011 at 2:33 pm
    Hi
    I’m trying to programatically change the input I am using with a Decklink HD EXTREME 3D Card. I need to change between SDI,HDMI,Composite etc. I can do this manually using the Decklink Control Panel found in Windows Control Panel.
    I’m looking through my files frantically trying to find some detail on the input variables used for the ActiveX commands used to control the Decklink Control Panel with no joy. I’m expecting to find some #defined values but am unable to find anything that looks like the data I need to put into my commands to get the commands to work.
    I’ve managed to create the interface but have hit a brick wall quiet early on!
    Can anyone point me in the right direction?
    Warren James replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
