Activity Forums Blackmagic Design Decklink and Soundtrack Pro
  • Decklink and Soundtrack Pro
    Posted by Roger Nall on April 29, 2011 at 4:00 am
    Dunno if anyone has tried a setup like this, but I’m experimenting with running the Decklink HDMI out to a consumer surround receiver, so I can switch between it, a PS3 and/or a blu-ray (or whatever HDMI signal). Works great except for one weird aberration. . .
    In Soundtrack Pro, I can setup to mix 5.1 and the Blackmagic HDMI audio passes through the receiver correctly except that the Center channel and the LFE channel are swapped.
    Went to the Audio Midi Setup utility and used the “Configure Speakers” tool to find that, indeed, the output of the Center was mapped to the LFE and the LFE mapped to the Center. Changed the mapping there, and it seems configured correctly there, unfortunately back in Soundtrack Pro, it isn’t different.
    Went back and did some tests, swapping other channels around and although the changes are reflected correctly in the Audio Midi Setup, it makes no change in Soundtrack Pro.
    Any thoughts, anyone?
    Pardon spamming the forums, but I posted this in the Soundtrack Pro forum as well. . .
    TIA
    Michael Cinquin replied 14 years, 11 months ago 2 Members · 1 Reply
