Activity › Forums › Blackmagic Design › Decklink 6.4 and 6.5.1 Windows and Premiere 1.5.1
  • Decklink 6.4 and 6.5.1 Windows and Premiere 1.5.1
    Posted by Christopher Tay on October 16, 2007 at 12:02 am
    I just updated a Decklink Extreme on a PC with a NVIDIA Quadro FX560 with both 6.4 and 6.5.1 driver and in Premiere 1.5.1, the Viewer and Canvas window has problem with the image display. It will just display horizontal streaks like as if an image has been horizontally stretched by a single pixel so all you get are just lines but it seems to represent the actual image. On the Decklink’s video output, it looks fine.
    I downgraded to 6.3 and now it behaves normally.
    Anyone else seen this with 6.4 and 6.5.1 drivers ?
    -chrispy
    Christopher Tay replied 18 years, 11 months ago 1 Member · 1 Reply
  • Christopher Tay
    October 16, 2007 at 12:27 am
    I forgot to add that the display problem in 6.4 and 6.5.1 drivers only happens when I use the PAL 8bit codec…if I capture them as PAL DV, the problem doesn’t show up.
    -chrispy
