Activity Forums Blackmagic Design Decklink 5.0 Windows & Premier Pro 1.5.1 – crashout during project opening
  • Decklink 5.0 Windows & Premier Pro 1.5.1 – crashout during project opening
    Posted by Christopher Tay on July 13, 2005 at 2:43 am
    I just did an update to Decklink 5.0 Windows and now when I open an existing project or open a newly created project, Premier Pro will report that it has encountered a problem that forces it to shutdown. It will then quit to the desktop.
    I removed Decklink 5.0 and it now launches properly. I reinstalled Decklink 4.8 and the problem doesn’t show up.
    Any advise ?
    -chrispy
    Adrian Tecson replied 21 years, 2 months ago 6 Members · 6 Replies
  • Dolby1970
    July 13, 2005 at 1:03 pm
    Same thing happens here. Also happens on creating new project.
    dolby
  • Matt Dowling
    July 13, 2005 at 1:43 pm
    Hi Chris,
    Can you give me a run down on the system?
    Also can you check with Blackmagic DeckControl application and see if that does the same thing?
    Cheers,
    Regards,
    Matt
    Blackmagic Design
  • Christopher Tay
    July 13, 2005 at 3:13 pm
    Hi Matt,
    The system is a BOXX PC running dual AMD Opteron 250s processors with 4GB RAM under WinXP SP2. It has a NVIDIA Quadro FX4000 graphics card and a RAIDCore SATA RAID card.
    The Deck Control application works fine. It’s only when you try to open a project or a new project, it will then report that it has encountered a serious problem and causing Premier Pro to shutdown.
    I have no problem as well with AfterEffects 6.5. It’s only with Premier Pro 1.5.1.
    Also, it has been working fine with Decklink 4.8 drivers.
    -chrispy
  • Yves De muyter
    July 13, 2005 at 3:23 pm
    What version of DirectX do you have installed ? The one shipped with Adobe ? Problems are often created by software you installed after Premiere…
    -Yves
  • Jo. S
    July 14, 2005 at 6:30 pm
    Hi!
    Exactly the same problem here…
    PPro doesn
  • Adrian Tecson
    July 19, 2005 at 6:33 am
    Hate to be the odd man out, but I’m getting the same problem on my dual Xeon workstation
    I currently have 2 decklink extreme setups, the Tyan/NVidia Geforce based station works like a charm on the ver5 drivers. Unfortunately, the Supermicro/ATI based station gets the serious error crash. Could it be graphics card based?
