Activity Forums Blackmagic Design Decklink 4K to SDI Multiplex to Sony PVM-X300
  • Decklink 4K to SDI Multiplex to Sony PVM-X300
    Posted by Kaku Ito on March 7, 2013 at 4:15 am
    Hello,
    Has anyone tested to connect Decklink 4K Extreme to SDI Multiplex to Sony PVM-X300?
    Trying to get the QFHD out from Resolve, Premiere and FCPX but none is successful.
    Dara Yem replied 13 years, 2 months ago 3 Members · 3 Replies
  • Chris Pearse
    March 7, 2013 at 5:38 am
    We tested this hardware combination with Resolve at a Sony event a few weeks ago and it worked nicely. Premier should work too. However right now I don’t think FCPX will output 4K.
    Have you made sure that the Mini Converter is set to perform the correct conversion using the dip switches? Please also make sure that the A and B links from the DeckLink are the right way around. However I think this would just swap the field order.
    If this doesn’t help, please get in touch with your local Blackmagic support office. You can find the support numbers here.
    Chris Pearse
    Technical Sales Manager
    Blackmagic Design Japan
  • Kaku Ito
    March 7, 2013 at 7:24 am
    Chris, I found out that the print on the Multiplex is printed wrong, the on/off are opposite. Once I figure that out, it worked nicely. But thanks anyways.
  • Dara Yem
    June 13, 2013 at 5:57 pm
    can i be your friend if u have the x300? prutty please
