Activity › Forums › Blackmagic Design › Decklinck Extreme 3D – How can I output a Frame-Packing Signal
  • Decklinck Extreme 3D – How can I output a Frame-Packing Signal
    Posted by Stefan Bauer on November 12, 2010 at 1:25 pm
    I am trying to output a Frame-Packing Signal from the BM Media Express Player to my 50″ Plasma 3DTV via HDMI 1.4 but i can’t get it to work.
    The only options in the BM settings for 3D Output are Side-by-Side, Top-Bottom, Interleaved, Left and Right. But there is nothing about Frame-Packing, where each’s eye resolution keeps the full HD resolution.
    By the way, I use two separate 1808p24 streams which I combined to a 3D stream in the software.
    Quirin
    Morten Schmidt replied 15 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • George Bellias
    November 12, 2010 at 8:49 pm
    What a coincidence, I just called in the exact same question to Tech Support. The rep did not know and is checking on it for me. I will let you what I find out.
    George Bellias
    Jade Productions
  • Allan Barnwell
    November 12, 2010 at 8:58 pm
    I’m having the same problem.
    The promotional blurb on the website says something about the card being intelligent enough to switch automatically, but I don’t see that happening.
  • Allan Barnwell
    November 12, 2010 at 9:46 pm
    Are both of you using certified 1.4 cable? I’m not but my other 1.4 devices are working with the one I have. That may be why the card isn’t auto recognizing the display.
  • Stefan Bauer
    November 12, 2010 at 9:56 pm
    Me not, but as far as I know HDMI 1.4 doesn’t require new cables . The confusing thing for me is the fact, that there’s just no option for the Frame-Packing mode in the BM software.
  • Allan Barnwell
    November 12, 2010 at 10:26 pm
    The 1.4 cables are capable of carrying more data for 3D. I’ve got one coming in the next hour and I’ll let you know if it fixes my problem.
  • Allan Barnwell
    November 12, 2010 at 11:59 pm
    So BM tech support said that at this time the current firmware does not support frame packing on capture or playback.
  • Stefan Bauer
    November 15, 2010 at 7:49 am
    ok but does anyone know how to get a hdmi display feed with a frame packing signal? Are the any other cards/converters? As far as I know the BM Extreme is the only card havinga hdmi 1.4a output
  • Morten Schmidt
    April 2, 2011 at 2:20 pm
    u need to go into the BM control panel and put the 3D feature to on
    I done playback with framepacking output to my Acer monitor
    MacPro 4.1 16GB Ram, 4x1TB drive BD-burner IOHD 2×30″ Apple Display and lots of stuff..
    Apple Rocks !
