Activity Forums Blackmagic Design Decklin Extreme troubles
  • Decklin Extreme troubles
    Posted by Marc Bauwens on April 25, 2006 at 6:56 am
    I’m getting strange issues with my Decklink extreme card.
    The card is PCI and when I try to capture footage thru the Firewire port, frames are dropping like crazy !! I tries the speedtest, but the test gives me ample speed for the required task. Anyway, when I disable the Decklin video desktop, I can capture without dropping frames, but the capture preview looks jerky although the captured footage is fine. I’m sure the issue is with the Decklink, because when I uninstalled it, Firewire capture is flawless.
    I think it might be related to some hardware, as I discovered that my ASUS P4C800E deluxe motherboard has 32-bit PCI slots instead of the recommended 64-bit. Could this be the bottleneck ??
    My complete config:
    ASUS P4C800E mobo with P4 3,2 Ghz and 2 GB DDR400 RAM
    Primary system disk Maxtor Diamondmax 9plus 80gb S-ATA
    RAID 0 for video, 2 Maxtor Diamondmax 9plus 80gb S-ATA striped with the on mobo RAID controller (Promise)
    S-ATA disk 200 GB for audio.
    Decklink extreme PCI card.
    Adobe Premiere Pro 2
    Do I need to get another motherboard and if yes which one (I’m in Europe).
    Thanks for any comments or suggestions that could clear this issue up.
    Marc Bauwens replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
