Activity Forums Apple Final Cut Pro Legacy Deck/Capturing advice
  • Deck/Capturing advice
    Posted by Marcus Bird on July 22, 2008 at 10:22 am
    I’ve been given some tapes that im told are HD, but believe they’re probably shot on HDV. I need to hire a deck to edit to footage together, if I pick up an SD deck will their be a loss in quality when I capture and if so, would a HDV deck plug in and run as easily, or would I need more equipment?
    The tapes are Sony ‘DV Premium’ DVM60 MiniDV.
    Thanks for the help!
    Marcus
    Marcus Bird replied 18 years, 2 months ago 3 Members · 4 Replies
  • Dunwoody Lampton
    July 22, 2008 at 12:17 pm
    What do you mean by “are in” HD?
    Does this mean that these tapes are specially designed at the manufacturer’s
    for optimized recording with HD camcorders and decks?
    Does this mean that there is HD material recorded onto a standard, MiniDV tape?
    A quick check through Google (and several years of experience recording onto these tapes
    myself) shows that the tapes in question are merely standard MiniDV recording stock,
    with absolutely no designation for optimized HD recording.
    Good luck.
  • Walter Biscardi
    July 22, 2008 at 12:25 pm
    [Marcus Bird] “‘ve been given some tapes that im told are HD, but believe they’re probably shot on HDV. “
    They’re one and the same. HDV IS HD. If they’re shot HDV, you cannot use a standard DV deck to play them. You must get an HDV deck to play them.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Walter Biscardi
    July 22, 2008 at 12:27 pm
    [Dunwoody Lampton] “Does this mean that there is HD material recorded onto a standard, MiniDV tape?
    with absolutely no designation for optimized HD recording. “
    Any MiniDV tape can be used for HDV recording. Those considered “Master” tapes and “Optimized” for HDV recording are always preferred, but as we have seen in our shop from tapes dropped off by shooters, any MiniDV tape will work.
    Read my Blog!
  • Marcus Bird
    July 24, 2008 at 3:02 pm
    Thanks for the help! They were HDV and I grabbed a HDV deck to capture everything. Some of the audio has a cracking to it though, my sequence is set to 48 kHz, 24-bit and channel grouped. What can I do to remove the cracking? The footage was capture through a HDV to firewire 400 cable with no separate audio input…
    M
