Activity Forums Adobe Premiere Pro Deck settings for export DSR-20
  • Deck settings for export DSR-20
    Posted by Steve Mac kenzie on October 9, 2006 at 1:33 pm
    In Premiere Pro 2.0 and I am having a difficult time getting the deck to assemble at the exact timecode. Is there a delay start setting for this sucker? To assemble at 10;00 I have resorted to 14;12 and though it is functional it is also tacky having to cheat it like that. I figure it must be a setting and someone has dealt with this before. Thanks
    Steve
    Craig Howard replied 19 years, 10 months ago 2 Members · 5 Replies
  • Craig Howard
    October 10, 2006 at 5:22 am
    Are you using the device preset for a DSR 20?
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Premiere Pro 2.0
  • Steve Mac kenzie
    October 10, 2006 at 5:13 pm
    Yes I am using the Preset for DSR 20 with 150 frame preroll.
    Thank You for your input!
  • Craig Howard
    October 10, 2006 at 7:08 pm
    Have you tried without your 150 frame preroll.
    eg the 4 sec 12 frame offset is 152 frames difference (@30fps)
    I use no pre roll on my DSR11
    Craig Howard
    Auckland
    New Zealand
    Premiere Pro 2.0
  • Steve Mac kenzie
    October 11, 2006 at 9:39 pm
    I never thought of not using preroll, this deck definately snaps to on command. The anti-umatic experience. I will work with this once I drop this next episode to tape.
    Thanks for your assistance!
    Steve
  • Craig Howard
    October 12, 2006 at 4:34 am
    Another little tip that maybe helpful.
    I had an issue with the video on PremPro displaying with an approx 1 second delay at the external monitor. ie the video on the PremPro monitor and the external monitor were about at a second variance. (Irritating to say the least) – turned out to be 17 frames variance.
    I fixed it by changing the msdv.sys file to the version used in Service PAck 1.
    If you are still with me here…
    This created a new litle problem. My dubbs to tape were exactly 17 frames out.
    I solved this by simply deducting the 17 frames from the Tape Record In point and this works fine and reliably. eg my workbar in point less 17 frames.
    Kind of a simple way to make the off set if you need any. (Just have to rember how much it is all the time)
    Craig Howard
    Auckland
    New Zealand
    Premiere Pro 2.0
