Activity Forums Avid Media Composer Deck problems
  • Deck problems
    Posted by Morten Raarup on May 10, 2006 at 1:14 pm
    I have ordered a MC and MOJO SDI, and until it are ready to ship, the dealer have given me a Xpress Pro. I use the mac version 4.8.4. But the troble is that I can’t get my DVCPro deck to work. I’m using Keyspan for the RS422 remote and loading composit into the mojo. My digibeta, Beta SP and DVCAM deck run fine. But the DVCPro deck wont work. There are a menu in the DVCPro deck whit changes the 422 protocol so when you auto-configure. the deck AVID thinks is a sony BVW 75, but that don’t help.
    Every time i try to capture AVID says: “Capture aborted due to discontinuity in timecode” The deck are a Panasonic AJ-SD93E whit SDI and analog option boars.
    I have also tryed to remove the mojobox and use the deck whit firewire, bu the result are the same.
    What can i do? I don’t want to by a new DVCPro deck, I have use the deck for 2 year whit decklink and FCP whit no troble.
    Morten Raarup
    On Off Line Postproduction
    Copenhagen, Denmark
    Jon Zanone replied 20 years, 3 months ago 3 Members · 5 Replies
  • Michael Hancock
    May 10, 2006 at 5:21 pm
    Discontinuity in timecode means you have a timecode break and you haven’t set up your system to capture across it. Under Settings, go to Capture and check “Capture across timecode breaks”. It will end your clip where the timecode breaks, but it should pick back up on a new clip and keep capturing instead of stopping.
    Mike.
  • Morten Raarup
    May 10, 2006 at 6:39 pm
    No that is not it. is stops after 12 – 24 frames. And there no tc jumps on the tape. I have tryed whit more than one.
    Morten Raarup
    Copenhagen, Denmark
  • Jon Zanone
    May 11, 2006 at 11:45 am
    Are you trying to capture DVCPro50 by chance? According to the device list (https://www.avid.com/content/8927/SUPPORTED%20DEVICES%20FOR%20AVID%20EDITOR%20PRODUCTS.pdf), DVCPro50 is not supported with this deck…
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Morten Raarup
    May 11, 2006 at 1:25 pm
    no – just 1:15s via mojo and rs422
    Morten Raarup
    Copenhagen, Denmark
  • Jon Zanone
    May 11, 2006 at 8:59 pm
    OK – dumb question….
    Are you sure you’ve selected the proper input in the digitize tool? Sorry for the basic question, but trying to imagine what’s wrong. If you deselect the TC track, will the capture work?
    Jon
