Activity Forums Apple Final Cut Pro Legacy deck not recognized when trying to capture
  • deck not recognized when trying to capture
    Posted by Robin Chin on March 16, 2008 at 3:50 am
    Hello,
    I am unable to get FCP to recognize my HDV deck in the capture window. What capture presets and device control presets do you use? Do I have to download a driver to use this deck?
    I am using a Sony HVR-M25U deck and shot on Sony HDV/DV tape (mini cassette).
    I am on FCP 6.0.2, OSX 10.5.1 on a Dual 2.3 GHz Power PC G5.
    I also will need to work on a MacBook Pro OSX 10.4.11
    Thanks ahead of time for your help.
    Robin
    Robin Chin replied 18 years, 4 months ago 3 Members · 3 Replies
  • Zane Barker
    March 16, 2008 at 7:00 am
    [robin chin] “What capture presets and device control presets do you use?”
    That depends on the settings you used to shoot with, You will want to use the same. HDV can use several different settings 1080i60, 720p24 for example.
    [robin chin] “I am using a Sony HVR-M25U deck and shot on Sony HDV/DV tape (mini cassette). “
    Sony does 1080, but you will still want to know the FPS, as some Sony cameras will give the option for a 24fps.
    [robin chin] “Do I have to download a driver to use this deck? “
    No but you do want to make sure that your deck is not set to down-convert to DV on play back.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • John Greer
    April 8, 2008 at 8:31 pm
    Robin, I’m having the same problems! It works very intermittently. I had it there for long enough to log & capture for a day, but now, a few days later, no luck!
    Same settings, three cables (changed them just in case), tried a DV tape with DV settings (just in case the HDV was the problem). Still no luck.
    Have you found any solution yet?
    THANKS!!!
    John
  • Robin Chin
    April 15, 2008 at 7:44 pm
    Here are settings that I got to work:
    Audio/video settings:
    Seq preset: DV NTSC 48 Hz
    Capture preset: HDV
    Device control Preset: Sony HDV Firewire
    Hope this helps.
