Activity Forums Apple Final Cut Pro Legacy Deck not performing insert edits…
  • Deck not performing insert edits…
    Posted by Michael Lansdell on February 20, 2008 at 2:30 pm
    Whilst trying to insert edit, Final Cut displayed the following message:
    “The deck may be unable to perform this edit operation since the edit duration is only one frame.”
    Except the edit duration, from in point to out point was nine seconds and ten frames. Any ideas?
    It didn’t perform any kind of insert upon clicking on okay, by the way.
    Oh, and anyone who pays close attention to this forum may of noticed I’ve been asking for a lot of help recently. Why is it that when you’re suddenly up against it problems you’ve never come across before suddenly pop up!? Many thanks to all that have helped me, you’re all stars! I hope that one day I’ll notice something I can help with, and feel like I’ve put something back.
    Michael Lansdell replied 18 years, 6 months ago 5 Members · 6 Replies
  • Walter Biscardi
    February 20, 2008 at 2:41 pm
    What VTR and what system are you using?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Doug Beal
    February 20, 2008 at 2:42 pm
    searching my somewhat damaged memory I had that problem once and repaired permissions and rescued my prefs. don’t know which one worked,buut it began behaving again
  • Michael Lansdell
    February 20, 2008 at 3:25 pm
    Hi, I’m using a DVW-A500P
    and I think the rest of the details should be listed below,
    Michael Lansdell
    Online Editor,
    Available Light Productions Ltd
    My system:
    2 x 3 GHz Quad-Core Intel Xeon
    5GB DDR2 RAM
    512MB ATI Radeon X1900 XT
    OS X 10.4.11
    Final Cut Pro 5.1.4
    Blackmagic Design DeckLink HD Extreme (6.6.2)
  • Jamie Pickell
    February 20, 2008 at 4:03 pm
    Michael,
    I’ve seen this problem before. The solution which worked for me, is to create a new sequence matching the settings of your other sequence, copy the elements you need to insert and paste them into the new sequence. Use the new sequence to do the insert edit. FCP can be wonky at times. I find a similar problem occurs when you change a sequence from a 2 track stereo to a 4 track stereo. FCP just doesn’t want to update the info correctly, so a new sequence seems to do the trick.
    Cheers,
    Jamie
    FCP 5.1.4… upgrading when time permits
    XRaid
    Dual 2.5 G5
    Kona 2
  • Chris Borjis
    February 20, 2008 at 5:44 pm
    [Jamie Pickell] “I’ve seen this problem before. The solution which worked for me, is to create a new sequence matching the settings of your other sequence, copy the elements you need to insert and paste them into the new sequence.”
    I had this happen once before myself. I lost a lot of hair that day (pulling it out hehe )
  • Michael Lansdell
    February 20, 2008 at 5:55 pm
    That seems to of fixed it. I’m left with another problem (which I had before, but hoped may be related), and that is one of Final Cut crashing an awful lot. Started a couple of days ago. Also very annoying, but not so bad as long as I save regularly. If it doesn’t sort itself out expect another post on the forum tomorrow (which’ll make it four days running, I think. Do I get a prize for that? It’s gotta be a record!).
    Thank you everyone!
    Michael Lansdell
    Online Editor,
    My system:
    5GB DDR2 RAM
    OS X 10.4.11
    Final Cut Pro 5.1.4
